Group\folder in variable info
Hi there, I’m trying to figure out if I can use the Group/Folder info a device is in, as a variable in the Recording path for the output file.
For example, I have a machine called Device1 in the Group/folder=Company1/London
I would like the Recording > Specific log file name to be = c:\output\$company$\$London$\$device$\output.txt
anyone know if this is possible??
Many thanks, Charlie.
All Comments (2)
Here's the structure that I have created in RDM as per your description
Company1 is a Company folder type
London is a Site folder type
Device1 is a SSH Shell session type
In the Advanced tab of the SSH shell session, in log path, here is what I have
C:\Output\$COMPANY_NAME$\$SITE_NAME$\$NAME$\$DATA_SOURCE_USERNAME$_$DATE_TEXT_ISO$_$TIME_TEXT_ISO$.log
This will create you a file with the name that your user has used to connect to the data source with the current date and the current time in the folder C:\Output\Company1\London\Device1
ah excellent...that works perfectly...thanks very much.
