Hey there,
I use RDM 8.0 and wanted to add a VMRC to one of my hosts. I have installed the latest VMRC SDK Plug-In 5.1 + VMware Player 5.0.2.
We use VMware ESXi 5.1.
Error while trying to connect:
"VMware Player is not installed properly on this system and cannot function. Please reinstall VMware Player."
Currently I'm unable to sort out what's wrong.
You need to install VMware PowerCLI. THe new version of RDM give you a better error message now.
Yeah, VMware vSphere PowerCLI 5.1.0 is still installed............
Could you check the application logs in Help->View Application Logs?
Yes, checked, but it's empty. I've tried to open several connections and sessions, but the log is still empty........
Should we activate some kind of logging to get more output?
Hmmm, found the new 8.1 version. Will try that and send a new message in some minutes
Ok, 8.1 throws same error
Could you post the print screen of the error? I want to see if this message comes from RDM or from a VMware product.
Attached the screenshot.
This seems to be an error from VMware. We invoke vmware-vmrc.exe in command line with -h {hostname}. Could you try this in a Cmd window?
Ahhhh, ok.
For testing I invoked the related command, same result. So it's a VMware issue.
Thanks for your assistance!
Mike did you solve the issue? I'm running into same troubles..
Hello I have a same problem I have esxi 5.1 and he ask me "vmware-vmrc.exe" I don't have what I need to do ?
thanks
What viewer do you have installed?
of course I have vsphere client 5.01 . also the remote is not working he ask me the path ???
I received the error :
unable to find remote console : VMware-vmrc.exe .
I have windows 8.1
It seems that the VMware Remote Console plugin is not installed
Hi, I got the same error in Windows 8.1!
Installed vSphere CLI 5.1, I pointed the vmware-vmrc to C:\Program Files (x86)\Common Files\VMware\VMware Remote Console Plug-in 5.1\Internet Explorer\...
When I want to connect to a VM with the "connect"-button, I get the following:
Also I don't know where I could change the setting of the standard location afterwards...
I have an ESXi 5.5 host. Can some help me with solving this...?
