Help with a script to batch add sub-connections.
I would like to create a script to batch add SCP sub-connections to entries within a specific group with the parameters below. Is this doable?
Use the built-in SCP application
Sub-connection name: $PARENT_NAME$-SCP
host: $PARENT_IP$
Credentials: Credentials store entry
Would anyone be able to help me with this? I have 60 entries to add this to and I'd rather not do them manually.
All Comments (1)
They have multiplied way to create that amount of entry. But to help you better, could you provide us :
The version of RDM that you are using ?
A print screen or the .rdm export of the SCP template you would like to create.
Best Regards,
David Grandolfo
