When you place the mouse over the search field, drop down arrow, (...) & x button no info is shown.
I'm not sure to understand by info?
It's the window that appears when you place the mouse over the items in the data sources which I have on the status bar. When I move the mouse over the filter section which is also on my status bar in RDM nothing happens until I move the mouse over the icon for the filter and the below window appears. If that feature does not warrant information on mouse over then that's fine. I was just listing it as a bug since most of the items in RDM support the additional info pop-up windows on mouse over.
edited by fvigo1128 on 3/10/2013
Ok,
The tooltip is only for the small image. I was not sure it this would be annoying it were on the combo box as well.
David, now that you mention it that way I see your point. I just thought that it was a bug in not showing the tips on mouse over for this particular feature.
