Credential Issue with Hyper-v Console
This maybe a bug. I created a hyper-v console that attached to a hyper-v system in the same domain as the local logged in workstation user and it worked correctly. I created another hyper-v console that attached to a hyper-v system that is in a different domain as the local logged in workstation user.
In the working system...
I click on my hyper-v console session and select open session, the session opens
I right click on a hyper-v guest and select connect, the session opens
I hit CTRL-ALT-DELETE and I get a login prompt for the guest.
In the failing system
I right click on a hyper-v guest and select connect, the session does NOT connect and it gives a login box coming from my local computer
If I say "use another account" and type in the correct credentials it does open the session and then I can send the CTRL-ALT-DEL to connect to the guest.
As an example.
Hyper-V console serverA.A.com, user running RDM is userA@A.com, credentials to connect to serverA are adminA@A.com everything works
Hyper-V console serverB.B.com, user running RDM is userA@A.com, credentials to connect to serverB are adminB@B.com I get the error above.
All Comments (1)
I saw that you have posted the same issue here https://forum.devolutions.net/topic27035-remote-desktop-manager--help.aspx?lastpage=1
We will continue to answer you in the other thread.
