Multi line tabs not being displayed for sessions
Hi
I've just updated to using RDM free 3.0.3.0 from 2.7.2.0 and found that the tabs for opened sessions no longer allows you to see all your sessions in the tabbed header as it isn't wrapping around and adding extra lines.
This is with the setting "use tab strip overflow (disable multiline tab pages)" disabled or enabled.
Is there a way to re-enable the multi-line tabs in the tabbed header?
Martyn
All Comments (2)
Unfortunately we had to change the thirdparty (deprecated) and it does not support it. I know it's a pain but I haven't found a workaround.
I'm really sorry. I hope that will be supported eventually.
Hi David,
Understood and thanks for the explanation.
It's such a shame it can't do it now as it was so quick to move between the open sessions. I'll just have to look at getting used to using one of the navigation views instead to switch between sessions rather than using the tabs instead.
Thanks anyway,
Martyn
Closed
