Disabling Always on top then exporting options hides dialog box behind application window
RDM 12.0.2.0
Prerequisite
I have dual monitors which may or may not affect this, I am not sure.
I also have displayfusion installed which also may affect this.
Options > User Interface > Advanced > Always on top ENABLED
Go to options > User Interface > Advanced > and DISABLE Always on top
Click Export Options
Click Save
Application window is then brought to front, in front of the Saved confirmation dialog box
You are then unable to click OK on the dialog box
All Comments (1)
We have been able to reproduce your issue.
A ticket has been submitted to our engineering department.
The workaround I found is to press Escape on your keyboard to get the window back.
Marc Beauséjour
