Just installed RDM version 12.0.2.0, and noticed this problem with the window (buttons in bottom of the window).
//Anders
Thank you for contacting our support services, in order to help you we would need the following information:
What version of RDM are you using?
What type of data source are you using? (File – My Data source information, use the "send to support" button.)
When you click "Deleted Entries" you should see that image below
Could you try to uninstall your RDM and reinstall it, perhaps the update process has been corrupt.
David Grandolfo
Hi David,
As it is saying in the first line (after "Hi,"), I have just installed the latest version 12.0.2.0. :)
I'm using a SQL-server - but the scheme hasn't been updated. (But I don't see a reason for a layout-issue because of that).
Yes, I can try to uninstall it.
Btw - I also tried to a full "Reset Layout", but that didn't change anything.
//Anders
Hello Anders,
I have assigned this to Samuel. He will look into it.
Hi again,
I have tried to uninstall and reinstall RDM - that didn't change anything.
//Anders
