Can't switch active RDP sessions using Navigation bar in 12.0
Hi, I've just upgraded to 12.0 and are finding that I can't switch between active RDP sessions using the navigation bar. When I select a new machine the screen does not update to the new machine, it just stays on the old machine and remains active (old machine is still responsive). In order to use the Navigation bar I must disconnect the session of the machine that I want to switch to, and then reconnect it.
I can switch between active RDP sessions using the Window List.
All Comments (9)
Does it work if you right click on tree item and click Focus session?
Hi David,
No, using focus session does not work either.
This is strange. I can't reproduce it here. I will ask the QA to test it tomorrow. Could you post a small video in the meantime?
Hi,i have the same problem here.
Just upgrade to 12.0.
Can't switch sessions by click navigation bar content.
And I tried right click the content then click focus but still not work.
The only I can find to switch sessions is a button up-right "Window List"
Is this a bug or I missed some configs in new version?
By the way, navigation bar works if i choose window=>"use tab title"(or what sorry im using chinese version)
Could you post a print screen of what you mean?
Just verified, if "Use Tabbed Header" is enabled then Navigation bar works, if "Use Tabbed Header" is disabled then the Navigation bar does not work.
Thank you. We should be able to reproduce it with your details.
We have reproduced the issue and it is now fixed internally. RDM 12.0.2.0 should have this fix, we will release this as soon as possible.
