Can not make high DPI connection to work.
I'm very confused what am I supposed to do so my remote screen respect DPI settings on my desktop. On my desktop DPI scaling is at 125%. My desktop is Windows 10 Annivesary edition and I connect to Windows 2016 box. There were some blog post saying that once I login into Windows 2016 it shall somehow inherit my client settings but after login it still does not work and all icons etc are super small. What am I doing wrong?
All Comments (56)
Our HDPI support requires 150% perhaps it's the problem. Have you enabled the HDPI support in options?
Where is in options I can enable it?
Found it. "Disable DPI scaling" is checked. Am I supposed to disable it?
What RDM version do you use?
Version 11.7.6.0
Here is what non scaled RDP session command prompt looks like compared to local one
Also just straight up mstsc.exe works fine as well (DPI is inherited), just RDM is not scaling
Could you post a print screen of the Help->Diagnostic?
Could you verify if it works in 150%?
No it does not work. Launching as external windows it works but launching in tab is not.
Do you still have the Disable display scaling uncheck with the 150%? You can verify in Diagnostic that RDM detect 150%
It works if I "disable display scaling". You can see on image below but now problem is that RDM is all blurry both in UI of application itself as well as inside RDP. Check below
Left is RDP, right is desktop
My mistake, you need to have it checked. When it's unchecked draw the refresh in a bitmap and scale it. That's why it's blurry.
If it's checked then all is crisp but scaling does not work unless I choose to launch in external window. I went to extreme and made desktop 200 and that's what it looks like desktop/RDM
Do you get the same behavior with RDCMan?
yes, the same issue is in RDCMan. I'm confused if you are seeing the same issues as me or you are trying to figure out if it's my computer specific. I imagine it's easy to reproduce.
Unfortunately I'm not able to reproduce it. The problem is that we don't really have the control over the RDP ActiveX. We can apply a zoom but I'm not sure what we can do to really fix the problem.
Your DPI scaling works fine when you connect from Win10 to Win2016?
I've never tried with a Windows 2016. I will try to setup an environment and see what I can do.
Which resolution do you set?
2560x1440
Thank you. I will test your exact settings tomorrow. Even with that I'm not sure if I can do something for it.
I've just tested it and it's really crisp for me on my SurfaceBook. Could you export me your session without the password? You can send me a private message.
Similar issue here.... it's checked and was previously working correctly. As of the latest update (v3.0.0.0) it's not scaling anything. Previously when I would connect everything appeared correctly. As of the latest update all connections are SUPER TINY (full screen or in tabbed interface). I connected to my local media server yesterday and it was fine. Today I launched, was prompted to upgrade, and now when connecting from my 3840x2160 display to any non-hdpi is super tiny when connected.
I confirmed in diagnostics that it's set to 175%.
Paul,
Could you confirm the Disable display scaling in File->Option is Checked?
Thanks for your information and sorry about that problem.
The problem is due to an option check by default with a new installation but not check when you upgrade from 2.7.1 to 3.0. Here are three ways to do it.
First, inside RDM go to FILE, Options,User Interface and please check the box “Disable display scaling on high DPI setting.”
If you can’t see that setting you can add the line in your config files directly. To locate your config files please follow that help https://help.remotedesktopmanager.com/installation_configurationfilelocation.htm
Once you find the right folder please open with a text editor your RemoteDesktopManagerFree.cfg under the line “<CreationDate>2016-11-14T00:00:00-05:00</CreationDate> please add, “
<DisableHDPIAutoScaling>true</DisableHDPIAutoScaling>
Restart your Remote Desktop Manager application and the problem should be solved.
Third way to do it is directly with windows options.
Right Click on your Remote Desktop Manager Free icon on your desktop Go to Properties and in the Compatibility tab check the box disable display scaling on high DPI settings.
Please see HDPI windows. jpg
Best Regards,
David Grandolfo
jason02
Disabled
I have the same issue - before i updated to 3.0.0 i had been using RDM fine with my Ultra HD display. Today i updated and no matter what options i try including disabling display scaling, the remote screen has tiny icons / fonts etc. It was the reason i started to use Devolutions instead of the Microsoft version... What are the solutions?
@Jason,
Did you try to apply that option with the RDM check box ? Did you restart your RDM application after ?
Best Regards,
David Grandolfo
jason02
Disabled
Yes i applied the check box and restarted the application several times...
Could you post a print screen of what you have?
