My RDM v11.7.6.0 running on Windows 10 is using a lot of memory. I've seen it use 8 GB with only 15 sessions running. That seems like a lot.
I suspect some of the Web Pages I am loading are using a lot of the memory. Example:
When I initially load RDM (no sessions running) Memory usage is at about 200 MB.
If I load a single IE embedded web page that starts with https://onedrive.live.com/edit.aspx/Documents/Daily?cid=..... , memory usage goes up to 1.1 GB
If I load a second IE embedded web page starting with https://onedrive.live.com/edit.aspx/Documents/Daily?cid= , memory usage goes up to 2.2. GB
If I close both IE sessions, RDM does not give up the memory. This must be a bug
If I exit RDM completely, RDM still does not give up any of the memory for at least 20 minutes, then it finally releases the memory. This is pretty odd.
Is this a known problem? Should I try another OS? Should I be using RDM 32bit instead?
RDM has not crashed but I get nervous when any app uses that much memory.
Note - The links I am using above are links to Microsoft Office 2016 One Note pages. I tried using the dedicated One Note option in RDM but it does not work... The URL is not parsed correctly. The front-end of the URL is dropped for some reason. Separate problem.
This is normal for the initial load. .NET consume a lot of memory at the startup and it's released when the OS needs it (Garbage collect). Could you try embedded Chrome instead of IE?
IE Embedded, memory is consumed by the Microsoft ActiveX, we have no control over that
Memory is not reclaimed immediately by the OS when there is no other demands from the system. If you run a memory stress application you should see RDM's allocated memory go down. Also, not all memory counters are significant, what column are you looking at?
I do not understand, do you mean that the RDM process stays on for 20 minutes or that the process disappears yet the memory usage is still high???
Maurice
