Navigation Panel not re-docking
11.9.4.0 installed.
I tried the (new?) "Dock As Tabbed Document" option for Navigation, but now I can't change it back as "Dock" and "Dock As Tabbed Document do the same thing and Dock it as a tab again if I drag it out of being a tab.
I normally have it as just an unpinned side panel, so I click it and it pops out, select what I want and it collapses again, trying to get this back but I can't now.
Andrew
All Comments (2)
Ok, got it, I had to grab it and drag it and get the placements to popup, then managed to get it back to being a left panel.
I expected "Dock" to have done that for me on a right-click.
Andrew
If you click on Windows -> Reset Layout, this will put back the Navigation Pane in is original position on the left side.
