i need to review more than the max. 1000 entries.
where is it to configure?
regards
markus
Kind Regards
Markus
I'm not sure if we have an option for that. I will assign this to Hubert to expose an option for that.
i understand that a gui-limit of 1000 is reasonable for performance, but report also allows only 1000.
regards
markus
Kind Regards
Markus
Hello Markus,
What version of RDM are you using, and what datasource type?
Using the latest stable version (11.7.6.0) as well as an SQL Server type datasource, I can see much more than 1000 entries in the Usage Log report (Administration > Reports > Usage Log), I am getting around 7800. I checked the code and there shouldn't be anything limiting the amount of entries showing up in the report.
Hi Hubert,
we use
RDM 11.7.6.0
DVLS 3.2.2.0
in both, "View Usage Log" and "Reports Usage Log" i only get 1000 entries.
"View Usage Log" shows on right side "1000 Logs" so I'm sure its OK, but Report shows only 1000 entries too.
so i'm only able to review approximately last 24h in our Usage Logs, because we create a lot of log entries.
Kind Regards
Markus
Thank you for the information Markus, the issue lies within DVLS as it returned only the first 1000 entries. This will be addressed in the next version of DVLS.
Thank you!
Kind Regards
Markus
