Database meta data location for a Connection object
jctp
Disabled
Where can I find , in the database, the location for the "Information" meta data (properties of a remote connection object), pic attached.
thank you,
You will find this information in the column DATA of the Connections table in the database. This information is saved in a XML structure.
Érica Poirier
