Workaround for greyed out menu items like "Add Document" and "Add attachment"
I'm using RDM 11.7.6.0 with Devolutions server 3.2.2.0 and I created a role with "View" rights. This implies that a user can't change the tree structure and session setting. As an unwanted side-effect the user can't add a document or an attachment.
If you supply Add-rights in the role, the user can change tree structure etc.
Is there a workaround to prevent users from changing the structures, but able to add documents, attachments etc?
All Comments (2)
I have been able to reproduce your issue.
A ticket has been sent to our engineering department.
Unfortunately, there is no workaround for it.
Érica Poirier
We are about to release a new security engine and we could add a new permission type to allow Add attachment but without giving the access to the tree structure.
Closed
