we are using RDM version 11.7.6 and we have created roles but when I select a user and try to assign a role I'm not able to select a role:
normally you can tick/select a role but the tickbox is not shown. I'm logged in as administratir. Any ideas?
regards,
Ivan
What type of data source are you using?
Érica Poirier
Erica,
Sqlserver.
regards,
Ivan
I have been able to reproduce your issue. Could you please check the size of text in the display settings of your Windows if it is set to 125%?
With the size of the text set to 125%, I have the same issue as yours but not with 100% or 150%.
Érica Poirier
Erica,
My text size was set to 125% indeed. Setting it to 100% did solve the issue. Thanks. This seems a bug to me. Will it be solved?
regards,
Ivan
A ticket has been sent to our engineering department to fix this issue.
Érica Poirier
