Not open external and undocked rdp sessions
megaxaser
Disabled
Hello, i have latest Remote desktop manager installed in windows 10 and when it updated to latest build (160715), RDM not open sessions if mode is external or undocked, only embedded sessions worked :( When i try open external sessions it try open it, button open session changed to Close sessions but nothing opened and after some seconds button changed back to open session. Options open console and Restricted admin mode enabled, i also see RDM log and found no errors, in windows logs also no errors. Could you please check it or may be i can send extended logs if it's possible.
All Comments (4)
Do you use the Enterprise or Free edition? Could you try the 64bit version if you have RDM Enterprise?
megaxaser
Disabled
I use free edition on my computer, but some time ago my friend with enterprise edition have same issue, i don't know if he run x64 version but exe file name was RemoteDesktopManager64.exe
megaxaser
Disabled
Yes, solution from first article works, big thanks, you are the best!
