Export not working for users and roles
I'm unable to export to any format in User and Security Management for Users and Roles.
Work fine for Security Groups.
Using RDM 11.7.1.0
Thanks
All Comments (5)
What type of datasource are you using?
What steps have you tried to export users and roles?
Érica Poirier
Datasource: MSSQL
I've try any type of export in user and security management : csv,html.xml.xls and work only in security groups
When I export user in xml see result
<?xml version="1.0" standalone="true"?>
-<Data_x0020_Export>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
<Table1/>
</Data_x0020_Export>
I have been able to reproduce your issue.
A ticket has been sent to our engineering department.
Érica Poirier
Thanks
This issue has been fixed internally. The fix will be available in the next version of RDM.
Ends in 3 days
