remove column entries on navigation pane
pedro
Disabled
How can I remove column entries on navigation pane?
All Comments (6)
You simply have to do a right click here and select Column Chooser;
Is this what you're looking for?
If there is anything else we can help you with, please let us know.
Marc Beauséjour
arrius01
Disabled
Your instructions show how columns are ADDED, now try to remove them using your method. The already present columns are not listed and there is no clear method to remove one.
@Chris,
If you want to remove a column, just click on the column title, hold the left mouse click and drag the column name outside RDM.
This should remove the column from the navigation pane.
jan09
Disabled
Thanks Jeff,
I was just about to ask this exact question.
A friend suggested RDM for me, and it looks really nice. :applause:
Best regards
Jan
@jan09,
Glad that you have found your solution on our forum! :)
This solution does not appear to work anymore.
