I gather that you are having to program all the user interactions that are normally done by Chrome. I two issues to report
One of the web pages I'd like to open, detects that Pop-ups are not enabled and asks me to enable them. How to I set the property in your embedded Chrome browser.
When I open the VMware vCloud Air site that uses vCloud Director, it prompts me to launch a third party plugin. See 1st attachment. RDM does not remember my choice, but normally I just click through it. However, if I don't do it right away, then the "dialog" window seems to die. Not matter what I click, nothing happens. In fact, I can't use RDM anymore. I have to kill it's task and start over.
Speaking of the third party plugin, it is the plugin that pops out a console window for any given running VM. This doesn't work. It seems to open up the pop-up as a new browser tab, but a error message is displayed. See 2nd attachment.
Thanks, Sue
Could you try the solution proposed in this topic to see if it helps with your issue
https://forum.devolutions.net/topic22365-using-chrome-to-access-vcenter-web-interface.aspx
