smart card authentication for gateways
Is smart card authentication for gateways supported on remote desktop manager? Using OS X 10.11.6 and cat seem to get it working.
Hi Ravindra,
Unfortunately, this is not supported and it's not currently on our to-do list.
I'll add your suggestion to the list and we will prioritize it.
Thank you for your feedback
Benoît Sansregret
This is because FreeRDP doesn't support it, correct?
Correct, we depend on them for our embedded RDP sessions
Benoît Sansregret
Closed
