Azure AD Connected PC and SQL Authentication
HI,
Is it possible to use Windows Azure AD login credentials to connect to the MS SQL Database?
We've got all laptops connected to Azure AD and we've installed a MS SQL2012 instance on a Windows server which is joined to the same Windows Domain. It would be really nice to let's the users connect to the SQL DB with these same credentials.
Kind Regards,
Patrick
All Comments (1)
It's on our todo list but I'm not sure we will be able to support this for RDM 12. We will do our best to add this after the release.
