Use data source to store and sync settings between clients (keyboard shortcuts, user interface, etc)
I have installed RDM on a couple of PCs.
I notice that settings I modify have to be applied to each system - e.g. changing a shortcut on my laptop don't apply to my desktop.
It would be nice to have a consistent feel across all computers, and also don't lose settings when I reinstall.
Is this possible?
Thanks,
Kristoffer
I will add a feature request for that. For now you can manually copy the configuration files:
http://help.remotedesktopmanager.com/installation_configurationfilelocation.htm
Hello David,
I have found that syncing the entire directory will copy everything - from window position to last closed sessions. Could you tell which files contain keyboard shortcut and UI changes (e.g. position of search)? I could then set up a manual sync with Git/Dropbox/similar for these specific files.
It's in RemoteDesktopManager.cfg (File->Options) and RemoteDesktopManager.Ext for the window position.
