Multi Monitor VNC
is multi monitor support for VNC added yet to RDM?
All Comments (5)
It's implemented only for Apple Remote Desktop for now. Which VNC server do you use? I might be wrong but from what I rememember the VNC protocol does not have a good implementation for the multi-monitor. I think that you need to use the coma to specify the monitor id
I am using ultravnc right now but will switch if you have had success with other implementations. Ultimately I am looking for a resonably priced Remote Software that does dual monitor and is embedded into RDM.
Just to make sure, you want to support multiple monitor locally?
Jonathan Lafontaine
yes preferably
Do you know if this is supported by any VNC client you know?
