When I log out of RDM and change the settings to Use Multiple Monitors it works great. When I log out that setting is lost and I have to do it again the next morning. Is there a way to save that as the default setting?
Which setting exactly do you change? Could you post a print screen?
Not sure that paste worked - attached screenshot.
RCD Screenshot.pptx
Your print screen displayed Microsoft RDP, not Remote Desktop Manager (RDM).
Are you using RDM? If yes, which version of RDM are you using?
