Report Help
When I'm trying to get a report of the credentials used to login in some specific servers, I found that the report shows the name of the credential entry but not the username defined in that entry, could you please explain me how to get this information if it's possible?
Thanks i nadvance
All Comments (4)
Thanks in advance
Unfortunately we don't have report that resolve the credential references. What kind of credential do you use? Some of the credential can't be resolved for performance reason (when it's an external vault ) but the simpler one could be.
Thanks for the update, we use the common credentials (username and password). but at the moment we can only retrieve the information of the credentials name, not credentials username.
With the provided credentials, it's okay because my team is the only one who can modified this. but in the case of personal credentials used to login to client servers is not enough. We have to be able to provide more specific reports to the clients in order to accomplish standars of audit process . could you please confirm if this is something that will be released in the next versions? or maybe if there are other solutions that could be applied only for this cases, we are not worried about the performance issues.
These reports are something that not will be regularly run, so I don't think that will affect us to much.
I will add this to our todo list.
