Small Bug I found Involving VMware Entries
When making a device entry for an ESX host, I made an entry as a VMware Infrastructure Client / VSphere Client. I then (before closing my entry) when to the sub connections tab to create an iLO entry for the device. [This was a duplicated entry from another ESX host, all I had to do was change IPs] When I went to change the IP of the iLO subconnection, i changed it from x.x.x.244 to x.x.x.241 and when I hit okay, and it was brought back to the sub connections pane, it still listed as x.x.x.244, not x.x.x.241; however when I went back in, it indeed saved it to .241, it just displayed ast .244 from the sub connection pane.
This is a very small bug, I just figured I'd report it and make you guys aware!
- Thanks!
- Matt
All Comments (2)
I will enter a bug report.
Thank you
This will be fixed in RDM 11.6.3.0. Thank you for your report :)
