Problem with eID-reader. Firsth card is ok. Reading next card fails
Environment:
Apple
Remote desktop session with Windows 2012r2.
Action:
Program is running. Try to read an eID-card. Window to ask to read the card. Clicking 'yes' -> good results.
remove eID-card and put a new one in de reader.
Try to read the card. Window to ask to read the card. Clicking 'yes' -> nothing occurs.
Disconnect the session and log on again. Try to read the eID Window to ask to read the card. Clicking 'yes' -> good result.
See log included.
Dan Casier
All Comments (12)
Hi Dan,
We rely on a component named FreeRDP to open RDP session in embedded tab in OS X. It is probably an issue related to this and I cannot guarantee we'll find a fix. I'll talk to our FreeRDP specialist and see what we can do.
To help us you could provide us with as much information you can:
- Your exact OS X version
- Your model of smart card reader and smart card
- Do you use any software to operate it?
- Any other information you might think relevant
Xavier Fortin
Hi again,
I've just talk with our FreeRDP specialist and it doesn't seem like we will be able to do much. He noticed one thing in the log though. There seems to be some error with the printers. Could you try unchecking the related check box in the RDP configuration: RDP >> Local Resources >> Local Devices and Resources >> Printers.
Xavier Fortin
Hi;
Any changes since I send responds on 28th of July?
Dan Casier
Hi Dan,
I was on vacation when I received your last email and my colleagues have forgotten to update me on your status.
I'm looking into your case right away and I will update you on our progress.
Apologize for the inconvenience.
Benoît Sansregret
Hi Dan,
Smart card operation really heavily on the hardware and software used for it.
We can't debug the issue without knowing what piece of hardware/software you are using.
even with that information, it might not be possible for us to quickly fix your issue.
We need to know:
Benoît Sansregret
