Users specific Settings "override hard drives"
is it possible to disable the Option "Override hard drives" in the User Specific Settings from a DataSource? This opens the possibiltiy to Exchange Data (security hole) between two Systems, and I don´t want to disable the complete "User Specific Settings".
Or does the "override hard drives" option not work, if you disable the Option in the RDP Settings from the Server?
Regards, Bernd
I could add a policy for that. Do you think it could help?
Yeah, that would be great.
Regards, Bernd.
We will have a new policy in the next minor version of RDM called DisableRDPHardDrivesSpecificSettings which will do exactly that. When it is out, could you try it and give us some feedback?
