Offline mode issues - Repeating authentication prompts after "Go Offline" + non-writeable search bar
tim02
Disabled
Since the last 3 updates I've had the following 2 issues.
  • Upon startup the application asks to authenticate, with the option to use Offline Mode. When I select to go offline, the authentication prompt just reappears multiple times. After 2 or 3 times clicking "Go Offline" on the numerous prompts. The application goes into Offline mode.
  • Next in Offline Mode, I'm unable to type anything in the Search bar. Ironically, I can write stuff when in Advanced Search
We use RDM Server and RDM Enterprise.
I've been struggling with this issue since the last 3 updates. I've tried changing some of the settings in my Data Source, but to no avail.
I tried recreating my Data Source. Didn't fix the issue.
I even completely uninstalled RDM, restarted, manually removed any remaining Devolutions folders in the %appdata% and Program Files folders, ran CCleaner, reinstalled and reconfigured this application, but the same issues still occur.
Could someone shed a light on this issue? Offline mode is basically broken for me.
All Comments (10)
What version of Devolutions Server are you using?
tim02
Disabled
I'm running the latest RDM version 11.5.4.0
Devolutions Server is running 3.2.1.0
Could you post a print screen (in fact, 2 print screens) of your data source configuration (File -> Data Sources). I need to see the Connection and Advanced tab.
I would also like to know if the Prompt for credentials before going offline option is checked in Administration -> Data Source Setting -> General -> Offline
tim02
Disabled
I don't have the tabbed interface like you have. Nevertheless here is my config:
Could you go in the Administration tab and click on Data Source Setting. Under General, you will found an Offline section.
Please post a print screen of that window as well.
tim02
Disabled
This section is grayed out for me. Probably because this section is only available for Administrators, which I'm not?
