Hello all,
I'm trying to achieve smartcard logon to a remote desktop farm over a RD Gateway.
Local smartcard logon using devolution's remote desktop manager works fine using the smartcard redirection feature.
Only from remote, the smartcard logon over gateway doesn't seem to work...
Yet, the logon method is clearly stated in the configuration window...
What am I doing wrong?
Thanks in advance!
We use a third party named FreeRDP for all of our embedded RDP session.
Unfortunately, the Smart Card login method for the Gateway is not supported.
You can only log directly onto the remote computer with the Smart Card.
The only way add this feature to FreeRDP would be to ask the community for it.
Here's the Github repository of FreeRDP https://github.com/FreeRDP/FreeRDP
Benoît Sansregret
