Is there a way to check between databases to find differences?
I have a local database and I'm wanting to be able to tell if the two online databases I created are missing anything from the local. Is this possible?
To check for the existence of entries, you would need to export both of them to the csv format, then use a diff tool (windiff, kdiff3, etc) to compare the output.
After you've ensure that all the entries are present, you then have to validate the contents. Fort that, use our RDM format. Sadly there will be many differences, especially in the datetime fields.
Maurice
