Hi all,
Is there a shortcut key for setting a VM window to "View Only"? That would be ideal for me! I just can't find a way to do it!
Thanks
m
Do you mean in an RDP session?
Yes. Sorry. That's what I meant :)
I use RDM with some automation testing I'm doing. It'd be great to start some automation and set to View Only quickly so I don't move the mouse and disturb the automation.
I will add this to our todo list.
Great! Thanks!
FYI for some reason I couldn't view this post on Chrome. Had to go to IE11.
See image for what I saw on Chrome.
Hi max,
We've been working on revamping the forum, and have had some problems with the cache!
It should be fixed, but if not, clear your forum cookie... that should do the trick!
Thanks
Matthieu Goulet
Had the problem still but cleared the forum cookie as you said. That did the trick!
We will add a customizable shortcut for the View Only button. You will be able to set it in File > Options:
I think this should help you in your use-case. When the next version of RDM is out, could you give it a try and check if this works as expected?
