CyberArk PSM integration
We have here a solution very similar to your Jump System, this system also connects to a remote server but without the user knowledge of the password of the next hop.
What it does is you need to set as the destination the PSM server and as the username you enter a string of parameters, the (pre-installed) client will integrate and stream the parameters to the destination connection.
I managed to configure a session using this method, it looked like this:
Computer: PSM-IP
User: PSM\%USERNAME%\$USERNAME$\Target-IP\Connection Component
PSM-IP is the PSN server smae as the Jump server
Target-IP is the destination server we need to RDP to
%USERNAME% is a variables
$USERNAME$ I get from the credential repository
All other are the installed client requirements.
The big issue is that the entry is not flexible, I need one time to login directly and another through the PSM, like you have with the jump.
I need your help in developing a menu similar to the jump menu (Open via Jump...) just Open via PSM.
How can I do this ?
Snir
Could you do what you want with a PowerShell?
You could create a template and a Macro Script Tool linked to this template. This will allow you to have it listed in the dashboard.
I'm talking about on the fly changes to the values and setting them back after the session finished.
I don't see how it could be accomplished with powershell.
Snir
It's not easy for us to help you without the environment. What can we do to simplify your work?
