I have the version 11.5.2.0 64bit running on Win 7 with 2 monitors.
I run RDP Manager on my right monitor and If I am in a spreadsheet or any application on the left monitor and use CTRL + SHIFT + Arrow then while the cursor moves in my spreadsheet, it also moves the focus between the different tabs I have open in RDP Manager.
You can disable those shortcuts in File->Options | UI->Keyboard
I think RDM should not react on keyboard input when it doesn't have the focus. Have the same issue here.
I can't even input an @ oder | in other applications any more, as the Alt Gr seems to be grabbed by RDM sometimes.
regards
Alex
Could you verify which mode is set in the keyboard options? Is it default or global?
See attached
I don't see the Navigation section in the print screen but just the General section.
