AWS S3 Not working, requires AWS4-HMAC-SHA256
While attempting to use the AWS S3 connector on Remote Desktop Manager it fails every time while connecting to the bucket. Looking at the application log I have several messages stating the below. It appears the plugin will need to be updated to use the latest encryption from AWS unless I am missing someplace to set this myself.
5/13/2016 11:30:08 AM11.5.0.0 - 32-bitError SilentAn Error, number InvalidRequest, occurred when listing buckets with the message 'The authorization mechanism you have provided is not supported. Please use AWS4-HMAC-SHA256.[/table]
All Comments (5)
We will look into it.
Sorry for the delay. The next version of RDM will have a fix for this. This is due to the region in which you created your bucket which wasn't supported with the old version of the AWS SDK. We have updated the SDK and this fixes the issue on our end. When the next version is live could you try it out and give us some feedback?
I would be happy to. I will keep an eye out for the release. Thank you for taking care of this.
I can confirm that this is now working with the latest release. Thank you once again for your work on this.
That's great :)
Ends in 6 days
