When I first set up my remote connections, smart sizing worked and it solved the problem I had with my 4K screen connecting to remote servers where the resolution was too high on the remote desktop and couldn't be re-scaled (making everything too small). Now I see that smart sizing is not working, if I use a tabbed or external window it gives me a smaller window, and if I use the full screen mode, it uses my desktop resolution, not the resolution I set in the display properties for the connection.
My connection has custom display settings with smart sizing on.
The remote server is a Win Server 2012 x64 R2. It's possible that since I set up the connection the server's admin has changed a policy that interferes with the remote connection, but I don't know what to look for. The admin doesn't think there is any solution for the display resolution issue and I told him about the Devolution product. Even if this is a policy issue, it's possible he's not aware of it as it may have been part of a security patch (this company is security-crazy).
How do I go about debugging this problem?
Thanks,
Carlo
I'm not sure how to debug it but we have a setting to change the Smart sizing mode while your are connected. This is in the ribbon and you could try to toggle it to see if it changes the display.
On another note you could try RDM Beta since we support now the HDPI. You need to enable it in File->Options
Check Disable display scaling on high DPI settings.
Thanks David,
A bit more info. I realize that previously when "it worked" I was opening in a tabbed window, then right-clicking to open in full screen. This works as expected. It was when I select "Open (full screen)" or "Open (External)" that this "failure to smart size" behaviour occurs.
My version is 10.0.10586.0
Is this behaviour expected? I also note that Open external and Open full screen can use the passwords stored on the local computer, but tabbed only is able to work with passwords in the DB.
Carlo
The Open full screen should work if it's embedded by default but for the external it's mstsc.exe directly. This means that we invoke the microsoft executable which does not work well in HDPI.
Usually we are able to use the password stored. Could you download the latest RDM beta and try the Copy Password to clipboard to verify if it get read?
http://remotedesktopmanager.com/Home/ThankYou?f=RDMsetupBeta
