Peer connection lost
On RDM Mac 3.5.1.0 when using RDP sessions through a gateway, I randomly get "peer connection lost" messages followed by a reconnection.
Export the connections, import them to RDM Windows 11.1.0.0 running in a vm on the same computer, same network, same adapter (a "shared" adapter managed by the vm hypervisor) and the connections run perfectly -- you can leave them up for hours without a blip.
I've seen this problem off and on in RDM Mac since the beta. How can we get it stamped out?
All Comments (1)
Hi yobyot,
There is many reason valid and invalid that might cause a Peer connection lost.
The best way we have to fix this kind of issue for you is with the RDP log file.
Set the Log filter to com.freerdp.*:debug and the file path to the location you want.
Connect to your session normally and when you see it disconnect for no apparent reason send us the log file.
We will be able to see what happened and we will try to find a solution.
Best Regards,
Benoît Sansregret
