I have been trying to customized default icons.
I have followed "Customize your Theme" and created two pair of icons based on the "Image List".
Tried to changed the "SessionsPutty" icons, this worked but when tried to change CiscoAsdm" icons, had no luck. I've tried in many different ways, and can't make the default blue icon with a circle and two arrows changed. Am I doing something wrong or the image list naming is not up to date?
I suspect that it does not work because it's an add-on. we will open a ticket to verify this next week.
Sounds good.
This is now fixed internally and will be available in the next version of RDM. It was indeed due to it being an add-on.
Is the fix going to be included on the next "Beta" build as well?
Yes, I'm not sure if we're shooting for another beta release before 11.5.0.0 or not but it will be in either the next beta or 11.5.0.0 for sure.
