help with recovering data
I have been using RDM for a number of years without any problem.
A couple of days ago it stopped working and after a few attempts to recover the 6.6.0 instalation without success I installed the latest version. I ended up with a new installation but without any of may old data! Is it possible to recover my old data?
thanks,
Ilir
All Comments (2)
Your old data was saved in a file called connections.mdb or connections.xml. It is usually saved in the folder%LocalAppData%\Devolutions\RemoteDesktopManager.
Could you verify the content of this folder. You could also do a search on your drive. I suspect that the new version is not linked to the right data source.
Hi David,
thank you for your answer. It was a matter of finding the mdb file.
thanks,
ilir
