After you change a entry via the filter dialog the filter is not refreshed.
double click filter field -> edit ->Change group position via keyboard input
greetings - max
You want rdm to select the same than the one in the filter?
This is now implemented internally.
The filter was set to the same text in both filter text boxes. (bet***)
after i changed an entry that i open via the filter dialog the filter refreshed on the navigation window but not on the filter dialog.
greetings
