Flash32_11_6_602_146.ocx Issue with RDM & or PVM
This may not be an issue with RDM 8.0.12.0, however to maintain a working application I needed to un-install the following from my machine which was an auto-install/update: Flash32_11_6_602_146.ocx. If you opened RDM or PVM and tried to interact with windows by for example simply clicking the start menu RDM & or PVM would crash.
Just wanted to put that out there if anyone would experience an issue with the Devolutions application try to remove the Adobe app/module first! I’ve also posted the issue to the Adobe forum and saw that that it is also having a negative impact on IE9 with tabs and certain websites.
edited by fvigo1128 on 1/17/2013
All Comments (1)
I've never seen that. Perhaps somebody else will be able to reproduce it.
