Paste immediate on right click in ssh shell
Would it be possible to configure "pasting immediate on right click" in a ssh shell session to a unix box? (Like you can in the windows command shell) Instead of "right click then click on Paste".
Peter.
All Comments (6)
Hello Peter,
Which version of RDM are you on? Are you using SSH Shell or SSH Shell (rebex)?
For the normal SSH Shell it should already work like this by default but you should be able to configure it:
You could try compromise or xterm, see if it changes anything.
