Error in connection with RDP Gateway
We have a connection to a client which uses two authentications, one for the gateway and one for the server.
Ex:
Gateway (aaa.aaa.com)
Server (bbb.bbb.com)
When I create a new RDP connection on Remote Desktop, set up as follows:
After completing the connection, we testify.
When we connect for the first time it appears the RDP screen with the data:
And soon after, the authentication error; even with the correct data
But, if we cancel the connection and try again, we managed to successfully connect.
What I understand is that the RDM is unable to log into the Gateway and Server on the same connection;
First it connects the gateway, gives the error
In the next connection, as was already authenticated at the gateway, can access the server;
It is a setting that was missing?
Tks
All Comments (14)
Do you have an User Specific Settings that override the gateway credential?
