Good morning guys,
I have a problem with the RDP connection using Gateway, using the embedded connection option (tabbed).
Join all connection correctly, using the RDP connection with embedded display:
Set the "Connection" tab, the gateway settings:
Start the embedded connection:
Even with the problem below:
Since the credentials are correct.
If I open in external display mode, I can not connect the server, however I do not have the connection log, because even when connected, the RDM asks me the comment closing the connection.
I remember that in an older version, I managed to connect to the server using this option. Was there any change?
Could you try to enable the NLA option above your RD Gateway configuration in your second print screen.
