Right click
After the latest update, while using SSH, my right click no longer pastes highlighted text but gives a right click menu. How do I fix this?
All Comments (5)
It seems we introduced an issue when adding support for the mouse click mode, we'll take a look at this.
Ok. Thanks.
Is there a way to roll back to the previous version?
You can download it from here http://cdn.devolutions.net/download/Setup.RemoteDesktopManager.11.1.6.0.exe If you want a different version just change the url to have the right version. If you want the zip, you can get it from here http://cdn.devolutions.net/download/Devolutions.RemoteDesktopManager.Bin.11.1.6.0.zip same thing for the version.
We found the issue and this will be fixed in the next version of RDM.
Closed
