Hello
Sometimes I Need to work on many Servers and have opened more RDP Connections, as there is place on the Tabs bar. Therefore the Tabs bar is getting wrapped to more then one row.
It would be great if the already openend RDP Connections are getting automatically scaled as soon as the Tabs bar is getting wrapped.
Otherwise, all the opened Connections are using scrollbars, which makes it difficult work.
Maybe this Settings can be made optional.
Best regards, René
Have you tried this display setting? Do a right-click on your session then go to Properties;
There are other settings that you can try.
Please come back to us with your results.
Marc Beauséjour
