Connection + Hyper-V Setting + Variable Substitution = Hyper-V Console doesn't open right
I have configured a template so that the user need only enter the server name in the Name field and the rest of the properties of the connection are completed using variables. Namely, Computer = $NAME$.mmi.local (take name of server and add FQDN).
Then on the Information tab, I selected 'Is Hyper-V server' = Default. After saving the connection, I rt. click the connection > View > Console Management > Hyper-V Console but when it opens the console Host says '$NAME$.mmi.local' so it is copying what is entered in the Computer field instead of performing the variable substitution.
All Comments (2)
Variable substitution must not be turned on for that type. We will look into this.
Maurice
This will be fixed in the next version of RDM.
