Text too small when using Remote Desktop on pc with High DPI Screen
I am connected to server 2003 from win7 notebook with High-DPI Screen (FHD) and 125% of normal size.
Text is too small when I use Full Screen. If I use other remote desktop size, like 800x600 or other, I get very small window and can’t zoom it up. Can I zoom or scale up this window?
Thank you,
Gregory
Could you try to disable the scaling on RDM.
Please follow instructions in the Screen areas unresponsive in embedded sessions section of the topic below:
http://help.remotedesktopmanager.com/troubleshooting_rdp.htm
I did it.
sfc, disable display scaling, tried to change session properties . .
I don't see any difference.
Objects on the remote window appear very small and text is difficult to read.
Could you post a print screen?
How can i insert PrintScreen in Reply?
Now i am connecting:
