Occasionally RDM responds to keystrokes when not active/focused
Hi!
I have a multiple-monitor setup. Occasionally when switching between RDM (version 11.1.0.0) and another program, RDM responds to [CTRL]-[SHIFT]-arrow-input when it is not focused.
That key-combination is used to select text in Windows, but it also switches to the next/previous connection in RDM.
Seeing that this key-combination is already a general Windows-combination, wouldn't it be more wise to change the 'switch between connections'-combination in RDM?
It shouldn't respond to those event when not active, anyways.
Sebastiaan
All Comments (2)
You can configure this in File-Options -> User Interface --> Keyboard
Have to confess I didn't Read The Friendly Manual.... Loads of options available, still trying to work through them at times.
Thanks!
Closed
